too much for my backhoe?
   / too much for my backhoe? #1
simmysam3
Spokane, WA
TYM 330 HST
I had cylinder seals replaced(boom) because i thought i had a problem, but that does not seem to be it.
I am exceeding my backhoe spec by of max 20" bucket with a 24", and when fully extended the boom cannot lift a full heaped bucket of soft, but wet sand.
I cannot imagine it not being able to lift the weight, but an extended lever like that extended to maximum reach - is it possible its simply too much weight?
its a small bradco 6.5' backhoe.
thoughts?
   / too much for my backhoe? #2
My little Taylor-Way couldn't do it either. With it's little 12" bucket I have to bring some big loads in a bit before I can lift it.
   / too much for my backhoe? #3
I think you will find that it is just too much for it to lift unless your relief pressure is not up to spec but i think it is just too much weight
   / too much for my backhoe? #4
If you are saying that the biggest bucket spec'd for this hoe is 20" and you have a 24" bucket on it, but expect it to fully extend that when full of heavy wet mud... I think you should be disappointed.
B'leeve it or not, manufacturers actually DO the arithmetic/engineering/testing, they do KNOW what it will do.
Sure, you can sometimes exceed one dimension if you are willing to accept a limitation on another dimension, maybe that is what you are seeing.
BTW, a 24" bucket isn't just 20% heavier than a 20" bucket.
If everything is in proportion it will have 1.2 x 1.2 the surface area in the sheet metal area.
It will be deeper and taller as well as wider, i.e. it could hold as much as 1.2^3 weight of material.
Both these factors will affect the distance to which that weight can be extended.
If you start beefing things up you run up against other limitations, such as loads on pivots and the stability of a tractor who's size/weight the particular hoe was chosen for.
Swinging too much weight around that far out could spoil your whole day (-:
   / too much for my backhoe? #5
Bet if you had that bucket full of wet sand weighed it would surprise you how much it weighs.
Have a 5 ton excavator with a 20" bucket and a full load of wet dirt will often pile higher but I can really tell a weight difference at full extension. My bucket is not at it's full width suggestion either.
   / too much for my backhoe? #6
thoughts?
Buy a 0-3000 psi gauge and see if they hydraulic relief if letting go at spec or low. They are very very very often sold at a lower pressure to keep you from breaking stuff. Especially while under warranty. If you get my drift....
Probably should be at 2500 psi, but your owners manual should tell you exactly. Adjustments are probably by adding a washer to the relief spring or by turning a screw to tighten it down. Pretty easy, about a 2 on the 1-10 difficulty scale. BUT, you have to have a gauge to tell what you are doing!!
What is the volume of the 20" and 24" buckets? Some wider buckets are quite shallow and will hold less. Then again some are wide and deep! And is it heaped or not?
If you really want to be able to lift the load, you can put on a larger diameter cylinder. Cost will be about 300 bucks or less.
jb
   / too much for my backhoe? #7
I can't see how it would not lift it when the backhoe is extended. I have a 15" bucket and it is only spec'd for 12". If it is too heavy it will lift the front before the cyliner stops moving.
   / too much for my backhoe? #8
The problem is probably how much preasure and volume your hydraulic pump puts out. They only put them in so big, and the smaller the tractor, the smaller the pump. The big difference between a commercial backhoe and a farm tractor of the same horsepower is the hydraulic pumps on the commercial tractors are much, much larger. Since they are not build for pullling anything or running a PTO, they can focus on the hydraulics. In a farm tractor, hydraulics are not the priority, so the focus is on the PTO and power to pull stuff.
My full sized, 555E backhoe has a 24 inch bucket on it. You are trying to use a similar sized bucket on your smaller tractor as I am, but without the hydraulics to support it.
It sounds like you are trying to lift way more weight then the tractor is capable of handling. I would be concerned about excessive wear and tear from exceeding the limits of your hydraulic system. You might be damaging your pins and bushing from the extra weight too.
Either buy a smaller bucket or a bigger tractor, everything has it's limits and pushing beyond those limits is never a good idea for the long term life of that equipment.
Good luck,
Eddie
   / too much for my backhoe? #9
;)I cannot imagine it not being able to lift the weight, but an extended lever like that extended to maximum reach - is it possible its simply too much weight?
thoughts?
:confused:I can as you're exceeding the specs.:eek:
   / too much for my backhoe? #10
jb
Bigger cylinders just leads to overloading elsewhere, including but not limited to the stability of the tractor.
At some point too much weight extended too far on too small of a tractor becomes a SERIOUS stability issue.
What next, longer stabilizer arms ?
Fatter cylinders all round ?
He is already OVER SPEC on this, single point beef up engineering won't solve the underlying problem.
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2021 John Deere C12R Corn Head (A53342)
2021 John Deere...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
