Too late to do a concrete slab in the North?
   / Too late to do a concrete slab in the North? #1
Gary_in_Indiana
Elite Member
Fort Wayne, IN
John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
Now that October is here I have the opportunity to do a concrete slab in part of my pole barn (40' x 48' with two outside walls and four doors). /forums/images/graemlins/crazy.gif Getting a floor in there would be wonderful but I'm concerned it might be too late in the season to pour and get a good cure for a lasting slab here in Northern Indiana (think Michigan's lower peninsula). /forums/images/graemlins/smile.gif
Is there any basis for this concern? Also, I'm thinking of going with 6" flooring over stone with some type of reinforcing and a minimum 4,000 PSI test mix with drains installed and aprons at the doors. Am I missing anything here?
   / Too late to do a concrete slab in the North? #2
Concrete produces some heat as it is curing. A tarp can be placed over the concrete and a heater blowing hot air underneath can also be used. Sometimes you can order the trucks with hot water. High early cement will also cure quicker and warmer but have to be finished faster.
Judgement call.
Egon
   / Too late to do a concrete slab in the North? #3
People pour in Canada all winter with the right conditions as Egon mentioned. Our neighbour poured in December last year, Daytime highs of -2 C. (Below freezing) he had some changes to the normal mix and used tarps.
   / Too late to do a concrete slab in the North? #4
   / Too late to do a concrete slab in the North? #5
There is a great article in the Journal of Light Construction on pouring concrete in cold weather. You may be able to get it from their web site. If not pm me.
<font color="blue"> "High early cement" </font>
Egon,
I'm not at all familiar with that term. /forums/images/graemlins/confused.gif
   / Too late to do a concrete slab in the North? #7
You should be fine as long as the ground beneath the slab is not frozen when poured, and the earth is packed, as well as the gravel is tamped. Fill dirt beneath the slab is what would concern me the most. It will settle over winter after being frozen.
But waiting will not improve the situation any. Frost around here this morning. Just made it up to 40 F. /forums/images/graemlins/wink.gif
It was cold and rainy when I got up this morning until about 8:30 AM yet beautiful the rest of the day. We're supposed to have our first frost Tuesday. I'm meeting with the concrete guy Monday AM.
If we can get together on our deal (it's a swap for a truck I have) then I'm going to want to do it ASAP. /forums/images/graemlins/smile.gif Thanks for all of your input.
   / Too late to do a concrete slab in the North? #9
Actually as long as the ground isn't frozen when you pour it or frozen withen 3 or 4 days after you pour it then you are fine. I would cover like has been mentioned. The worst thing to do with concrete is pour on a 90 degree day because the faster it sets the more brittle it is. The longer concrete takes to cure like in cooler weather the better it is. I would put a GOOD sealer on it as soon as it was hard enough to walk on.
<font color="blue"> "As long as the ground isn't frozen when you pour it or frozen within 3 or 4 days after you pour it then you are fine." </font>
Are you talking about it being frozen solid or a frost? I should be quite a ways away from the actual freezing but we're getting our first frost of the season in a few hours.
2014 Ford Escape (A50323)
2014 Ford Escape...
2016 BOBCAT S770 SKID STEER (A52705)
2016 BOBCAT S770...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
