Too hot for the alternater?
   / Too hot for the alternater? #1
jbw1963
Kioti DS4110
I am getting ready to start my ROP lighting project and want to get some opinions on the lights I am thinking about using. I have been considering using 130 watt off road lights, two forward, one to the rear. Would these be too hot for the alternator? or should I go with the 55 watt halogens instead? I want to throw as much light as possible.
   / Too hot for the alternater? #2
It's amazing how little light it takes to see in the dark.
   / Too hot for the alternater? #3
I just put some lights on mine. I found that two 35 watts out front were not enough. I ended up with two 35 watt and 2 55 watt out front and 1 55 watt out back. Don't know how much charge your alternator puts out but 3 - 130 watt lights will suck up 32.5 amps if all on at the same time.
   / Too hot for the alternater? #4
My CK30hst has a 50 amp alternator. Maybe a bigger DK has a larger output. That may be only leaving @17 amps for the rest of the tractor if all three were on. I would be trying less wattage lights. You'll be surprised at what those 55 watt lights will do. I have one for the rear and I see fine.
   / Too hot for the alternater? #5
Two 55 watt lites will give you 2 360 degree circles of light all around your tractor .
It all depends on how they are mounted and wired up.
   / Too hot for the alternater? #6
If I were concerned about my alternator's output I would get some LED lights which do not use as much energy- amps from the alternator. Less strain on your tractor.
Try superbrightleds.com
LED lights are more expensive than halogen or std bulb lights but they offer longer lasting bulbs and lower wattage usage. Check out the section that shows lights for RV's, Fork lifts, atv's, etc.
   / Too hot for the alternater? #7
The rating of an alternator is based upon the engine running fast. At idle it is much lower. So you can easily run the battery down at idle. With LEDs you can run for quite a while with the engine off. I have each front lite on a separate switch so I can reduce the power consumption when needed.
   / Too hot for the alternater? #8
What lights are you running on your rig?
   / Too hot for the alternater? #9
I have three LED headlights. Two in front and one in back. I don't know the brand. The $60 one puts out a lot more light than the $30 one. With the 15 amp alternator on the Power Trac 422, I was concerned about discharging the battery. There is a cooling fan that pulls about 5 amps, so that takes 1/3 of the current.
Edit. The nicer one has only 7 leds, versus many on the not so nice. It also had a flat heat sink grid on the back, versus a rounded back. It is several years old, so there are probably better ones out. It is not as bright as the Halogen ones I had earlier, but very adequate.
Another Edit: The LED is a truck star with 6 LEDs and is sold by Northern Tool for $69. It pulls a little over 1 amp, one fith of a typical headlight.
   / Too hot for the alternater? #10
Thanks Bob, This will hopefully be useful to the op too.:)
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
Scag Mower (A50324)
Scag Mower (A50324)
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
New Long Forks (A53002)
New Long Forks...
2002 Western Star Trucks 4900 SA Truck (A51692)
2002 Western Star...
