Tomato horn worm hunting made easy/easier
   / Tomato horn worm hunting made easy/easier #1
nickel plate
Veteran Member
CA
2002 New Holland TC40S
After years of trying to eradicate tomato horn worms from from my vegetable garden I think I have finally hit on a mechanical, non-chemical method of keeping them in check.
I've tried everthing that has ever been suggested to me including hunting them in the moonlight with a flashlight, (not a good idea as it almost sounds like a snipe hunt) searching out the eggs (too much leaf twisting and poor results) to various toxic and non-toxic solutions.
My weapon of choice is a pair of 10" scissors, 12" may be better for reaching into the plant but 10" works just fine.
Hunting time is early in the morning or at dusk (I prefer the A.M.) when the sun is not on the plants or anytime they are in shade. These conditions make seeing the targets alot easier.
The targets are leaves with hole(s) in them, very easy to see. Hold onto the leaf and use the scissors and cut off the leaf leaving the rest of the stem intact. Turn the leaf over and you will 99% of the time see a newly hatched small tomato horn worm. Again use the scissors to cut the leaf AND the tomato horn worm all in one slice! Discard it and move on. This method of single leaf removal also helps to easily locate future fresh targets without having to look at the same holed leaf more than once. HINT: Concentrate more on the middle aged leaves and not the real young ones as the worms need a length of time to hatch out and punch that first hole. I have ten plants and when I began this method of hunting a few weeks ago, I would get a couple of dozen leaf worms a morning along with many four inch "lunkers". I think that now I have broken the growth cycle as I am down to about a half dozen leaf worms a morning and practially no lunkers however the eggs are still being laid.
Search for the eggs while hunting the holed leaves. They look like a white pearl about the size of a pin head, maybe just a bit larger. They are layed individually and glued to the top or bottom of the leaf so cut the leaf off and pinch the egg between your fingernails and it will pop. Use any other method of extermination if that makes you squeamish.:laughing:
Finding and killing the 1/4" long juvenile (I photographed a larger worm so the camera would pick it up better) is more effective than searching out the 4" highly camouflaged adult worm in that you are saving the destruction of quite a bit of still producing tomato foliage.
Good luck and good hunting.
   / Tomato horn worm hunting made easy/easier #2
Thanks for the tip. I thought I was doing good to find themwhen they're about 1.5" long. Usually they're about 3" long before I find them. :D
   / Tomato horn worm hunting made easy/easier #3
Two words- bacillus thurengensis or BT. It's a bacteria that catepillars eat and then they eat him:thumbsup: Its been in use for years and is extremely safe. TSC will have it.
PH
   / Tomato horn worm hunting made easy/easier #4
I have removed over a dozen this past week. Some in the 4 inch class. I did mash one under my foot, he turned his rear up and got me in the face. First time i been assaulted by tomatoe worm..They had started to eat the fruit not just leaves..
   / Tomato horn worm hunting made easy/easier #5
They have the best camoflage of any insect I have ever seen. Sure can drill some holes in your tomatoes. Sevin is my friend.
   / Tomato horn worm hunting made easy/easier #6
Years ago an old fellow and I grew tomatoes on his ground. He furnished everything but the labor. When we had an epedemic of worms he suggest I make some bird roostes. Just simple stakes with a cross section near the top. He informed me that because the worms were so hard to see the birds required a elevated spot to see them. It worked. He also convinced some youngster that the worms were the best fish bait you could get. That worked too for bait and getting rid of the worms. (one of those Win Win deals)
   / Tomato horn worm hunting made easy/easier #7
My chickens love them. They do peck some 'maters too but not too many when fat yummy worms are available.
   / Tomato horn worm hunting made easy/easier #8
Good idea on chickens but i don't have any and my Mators are out the tops of the wire cages. I did not find a single worm yeserday, first time in over a week?
   / Tomato horn worm hunting made easy/easier #9
I think a Shotgun would work. Just have a few jars ready to put the tomato paste in. :laughing::licking:
   / Tomato horn worm hunting made easy/easier #10
They are awesome catfish bait. Don't smush em, put them on your trotline.
NEW Woods Reverse Rotation 5ft Tiller (A55218)
NEW Woods Reverse...
7046 (A50322)
7046 (A50322)
2015 Dodge Grand Caravan (A53424)
2015 Dodge Grand...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2430 (A51248)
2430 (A51248)
