Toggle Switch
   / Toggle Switch #1
Scotty Dive
Platinum Member
Ct
Yanmar 2020D
I am thinking of removing my horn button and replacing with a toggle switch that will power added roll bar lights and a back facing utility light. I need the toggle swtich to have off, on (front facing lights), on (back light) and both (both front and backup). The usual googling for a 4 position toggle switch is coming up empty. Does such a switch exist? Am I using the wrong search term?
   / Toggle Switch #2
You may find a 4 way pull switch instead of a toggle,
   / Toggle Switch
thanks...re thinking this now.....called around and found that a 4 position toggle doesn't exist.....
   / Toggle Switch #4
Scotty,
Its no biggy just use a std 12v double pole double throw switch. Wire the B+ in the middle and the lights to the outer terminals and ground the lights somewhere by them. Just make sure the switch has a detent middle position or neutral position in other words.
http://shop.vetcosurplus.com/catalog/product_info.php?products_id=8773 quick search an example for you.
on-off-on dpdt
   / Toggle Switch
No biggie for you maybe...LOL....but for me...thats another story.:laughing::laughing:
Am I right that a double throw will have two on's and one off? I need three ons and one off...
On 1 - Front lights
On 2 - Back light
On 3 - Front and Back lights
   / Toggle Switch #6
On 1 - Front lights
On 2 - Back light
Yes you are correct a dpdt would only have 2 ons sorry I read things wrong been doing that a lot here lately.
I am now thinking along the lines of and I dont have an example handy but a rotary switch is the first think to come to mind I will ponder this awhile and get back to ya.....
http://www.grainger.com/Grainger/POWER-FIRST-Rotary-Switch-2VLR8?Pid=search there ya go.
   / Toggle Switch #7
Another possibility is something like this which is already wired to do what you want (off/on1/on2/on1&2). I have one in a lamp. You might try to find something with some moisture resistance though.
   / Toggle Switch
That is exactly the switch I need. Two problems... they are like $60 bucks and they are not being produced anymore...only special runs according to cole hersee.
Think I will just use a single on off for the front lights and a seperate switch located on the fender or similiar for the back light
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
