Dadnatron
Veteran Member
I am building a mid to upper level horse barn for thoroughbreds. I have the design and layout and am now trying to spec it as well as possible in order to get accurate and comparable bids. I've spoken with several contractors and there seems to be a wide range of what is best, necessary, or nice.
The barn is a T-shaped barn, long axis is 120' with small 14' portion jutting out from the center for a small aisle and additional space and central entrance. Overall, there is approximately 10,000 sqft of roof space, with a simple hip roof design at a roughly 9/12 slope.
My question is whether I should sheath the roof or not. One builder believes in using sheathing and Snap-Lock type metal roofing without any exposed fasteners. I admit I like this thinking a lot, however, the sheathing alone will add $10,000 in materials + labor and I don't know how much of a premium the metal roofing system would add.
Another builder believes it is best/adequate to simply use the Double-bubble type reflective roll insulation over purlins and lay the metal roof directly on top, securing with screws. This is how he built his own barn, which I've been in.
I'm not sure what the overall cost difference will be nor the benefits/problems associated with each comparably. Barn is in Kentucky. Air tightness is NOT an issue, again, the barn is designed to ventilate very well. But it will have some large animals in it so there 'could' be a humidity difference in/out at times, especially on very cold winter days/nights.
1. What is your opinion on whether it is worth it to sheath a barn designed to be well ventilated?
2. If no sheathing, is the 'Double-bubble' insulation useful/adequate?
3. Is there a 'heat' worry if there is no sheathing/ventilation of metal? ie will my barn become an oven?
4. How 'loud' is a metal roof without sheathing, in a rainstorm? Does the sheathing mitigate that issue to a useful degree?
5. Without sheathing, I don't think the 'invisible fastener' metal roof systems can be used. I don't want to deal with leaking screws for the rest of my life if I can reasonably address it now. Are these systems worth the cost?
