To Blade or Box?
   / To Blade or Box? #1
duckhunter27
Dannebrog , NE
Bobcat CT 335
Hi guys I have about a 1/8 mile driveway and was wondering the diff. and or witch is better a rear blade which I have a 7 ft or a box blade which i dont have but may get one if better . also will a box blade work for snow?
   / To Blade or Box? #2
Firm believer you can do more w/box blade..other than cleaning slope ditches.
Far as snow removal,some folks on TBN do use box blades but most go w/rear blade..than onto blowers.
   / To Blade or Box? #3
Ideally, you need both. Read all about the pros and cons of each in the attachments forum.
   / To Blade or Box? #4
I have the 335 too and like my rear blade for snow. I have a 6 foot and it is too short when angled to get past both tires. Your 7 will do better. For the driveway I prefer a landscape rake (mine is a rock driveway 1/4 mile). My neighbor uses asphalt millings and prefers the box blade. If I was to choose between box and rake I would go with box for versatility.
   / To Blade or Box? #5
by the way let me know when the duck are moving out of your place this fall as they will be at mine the next day!
   / To Blade or Box?
Wow i didnt even know there was a attachment fourm this place is great lol. Thanks for that . As far as the ducks i will let ya know about the ones that get past me.
   / To Blade or Box? #7
I use a boxblade removin snow all the time, its nice cuz it fills up and doesnt trail out. Makes for less passes of snow removal.
   / To Blade or Box? #8
I'll sometime use a box blade in the snow but just because I don't have a rear blade :). If there's more than just a few inches on the ground, the box fills up fast and you have to stop, raise it, get off the tractor, get a stick or a shovel, and keep shoving the snow down and out of the box. It gets old real fast, and I can see how a rear blade would be much better. If you spray the box with fluid film or something similar, the snow "may" slide out when you raise the box, but if it's wet and heavy, it can get stuffed in there pretty good.
2014 John Deere 700K LGP Dozer (RIDE AND DRIVE) (A50774)
2014 John Deere...
Blue Bird School Bus (RUNS)(TITLE) (A50774)
Blue Bird School...
2018 JLG 1932R 19FT Electric Scissor Lift (A50322)
2018 JLG 1932R...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52748)
2022 Gravely...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
