Hi All,
My hydraulic lever tends to drift UP. It stops at about the halfway point if it was pushed down passed that. I read that this is just a friction disc thing and I just need to replace that or tighten up the lever. Is that true, or is there something more critical happening internally that should be looked at?
Also - when plowing, my plow tends to "bob" up out of the furrow every 20 feet or so, then it goes back down. Probably not adjusted right, but its frustrating. This is the draft control kicking in I believe, but it seems to be correcting too much. The soil is heavy clay, and is relatively consistent so I wouldnt think it should pull out..and even if it does, it shouldnt come out this far. Can you adjust the sensitivity of the draft? Is that something at the top link spring?
Here is a third thing for all you old timer experts. My furrows, when I actually get one to work, dont generally throw the sod (plowing a virgin pasture with a sod layer on top) completely upside down. Instead it sort of flips it 90 degrees so the end result after a few passes is I've actually stacked my sod side to side. Quite a sight really. Sometimes they roll completely over real nice but they also do this stack business. If I crank up the speed in the hopes of throwing them completely over, the plow/draft ends up kicking and out pops the plow.
Im better than I was, but far from good. Maybe a C+ at this point
Cheers,
Bob
Cheers,
Bob
