to 30 cracked block
   / to 30 cracked block #1
Midmud
medford, wi
ferguson to 30
I have a ferguson to 30 with a z129 engine with a cracked block. I heard this is a standard problem with the z129. My question: Will a z134 bolt into the to 30 tractor, and did the z134 have the same problem of cracking blocks? Help!
   / to 30 cracked block #2
dunno about the engine swap, but I do know that if your crack is the 'standard' Ferguson crack, then it may be able to be fixed by bolting the sides of the engine together.
Check out the yesterday's tractors web site for details.
I guess I was lucky as I've had a 1952 TO30 for over 25 years and never had any issues.
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
1990 Nitro Bass Boat with S/A Galvanized Trailer (A51694)
1990 Nitro Bass...
Case 1020 25ft Draper Head (A53473)
Case 1020 25ft...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
