TNT with quick hitch?
   / TNT with quick hitch? #1
galaxie428
Rushville, IN
Bobcat CT230
I use a quick hitch on my 3pt and was just curious if this would still work with a TNT? I know the top link would be ok but will the side work? I don't recall there being a lot of extra room between the hitch sides and the arms on the 3pt. My quick hitch is a Harbor Freight hitch.
   / TNT with quick hitch? #2
No problem. Do you already have the 2 rear remotes needed?
Thanks MtnView. No, I do not have two yet. I only have one so far. I will be piecing this together for a while as it is a big expense. I should have just gotten the two remotes when I bought the tractor!
   / TNT with quick hitch? #4
This is what I try to tell most everyone, get as many as they offer or a minimum of 2. But when a person is a tractor noobie either they can't figure why in the world would anyone need remotes or they just plain don't even know about them. Even if the dealer brings them up, same thought, "why would I need those"? So there is a learning curve and people start adding them as they realize how much better things can be.
We have all made similar mistakes. ;)
   / TNT with quick hitch? #5
I'm not sure what model you have but my CT235 came with the manual type tilt that you have to crank (have not use mine yet though). If you want to use one now. But I'm not sure how far down it goes. And I also have the HF quick hitch with CCM HTL. You can also install the additional remote your self if you are handy. It is not that hard. Reading the instructions takes longer than installing it.... :D (who reads instructions anyway :D). After you remove the seat of course :thumbsup:.
   / TNT with quick hitch? #6
I second that galaxie428 I am waiting to put my 2nd set on too. I think a large percentage of Bobcat buyers were noobs I wonder what the actual percentage was I was/still a noob learning as I go right now I gotta do the BB first.
Dont want to hijack the thread galaxie428 just wanted to ask how that HF Q/hitch works did you have to do any mods to work with different attachments? One reason I brought the Bobcat was the ease of hooking stuff up with the adjustable 3pt arms but I still have to get off the seat I know Kubota wanted extra I think $150or200 just for that Thanks and sorry about the question
Personally, I never thought I would ever use the second remote, I wasn't sure I would ever use the first remote. I bought a backhoe this year so I do have a use for the one set.
The QH works very well. I did have to modify an old finish mower I bought but it was easy to do. The tiller I have hooked right up. I also made a rear ballast and a trailer hitch but I made them to fit the QH.
I have to remove it when I hook up the BH which is kind of a pain but I also have to remove the anti sway bars too. I takes about 30 min or so to remove all that and get the BH hooked up. It would be quicker with a spotter but I have a hard time lining up the BH with the mount because I can't see it.
   / TNT with quick hitch? #8
NO. Top will work work with the 3pt QH, but tilt is significantly impaired and in some cases totally defeated by the hitch restricting normal articulation of the ball ends that fit into the QH slots. The slots are narrow and leave little or no room for ball to swivel wrt the lift arm, which they must for tilt. Bummer
larry
   / TNT with quick hitch? #9
larry
Larry are you sure? My Harbor freight quick hitch has full range of motion on my 3215.
   / TNT with quick hitch? #10
Have you tilted it :confused: Its gotta be either wrenching the arms against the lift links and tractor ends ... or youre flexing the QH / both. Or its nothing like my HF hitches that just give barely enuf room to fit the balls.
larry
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2018 Maserati Ghibli Sedan (A50324)
2018 Maserati...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2022 BARFORD TR8048 MOBILE SCREEN (A51242)
2022 BARFORD...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
2018 Wacker Neuson WL 38 (A52128)
2018 Wacker Neuson...
