TNN 55 ignition switch
   / TNN 55 ignition switch #1
aglee
Loudon, TN
TN 55
Installed a new ignition switch on a TN 55 Tractor. The tractor will start, but will not shut off.
   / TNN 55 ignition switch #2
On some machines (including mine) the key doesn't shut it off. Diesels don't have ignitions so if no electric fuel pump or electric injectors or shut down solenoid you use the throttle to turn it off.
:welcome: to TBN
   / TNN 55 ignition switch #3
Sounds like you connected the fuel shutoff solenoid wire to a positive leg on the switch OR the new switch is faulty.
Why did you replace the switch?
   / TNN 55 ignition switch #4
Was the switch OEM or generic?
Generic might not be exactly the same connections, (but 'almost')
The shutoff solenoid would be a normally closed wanting a switched power connection.
20" Sea Container (A47384)
20" Sea Container...
2019 PETERBILT 567 TRIAXLE (INOPERABLE) (A52472)
2019 PETERBILT 567...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
