TNF75A Trasmission problem
   / TNF75A Trasmission problem #1
crb111
bristol
TNF75A
Dear all, lately I was in my field with TNF75A.
All of a sudden the transmission lamp started flashing and the tractor shifted to high automatically and moved in forward only.
It seems that all of a sudden it went crazy.
Now I am in hold of a circuit diagram and I am checking the solenoid Valves one by one, and by powering the forward solenoid manually I managed to drive the tractor out of the field.
My question is regarding the combination of solenoid valves the tractor has as I do not know clearly their function.
It has two , which are labelled as forward and reverse which I assume are the forward and reverse driving solenoids.
Another is the dump solenoid which seems to dump all the hydraulic pressure to off load the pump ( actually I do not know its main purpose)
Another is the HI-LO solenoid which I think shifts from LOW to HIGH range and versa, although when I applied power on this solenoid when in forward I saw no difference in speed.
The last valve which is present and I have no idea at all of its operation is the shuttle mode solenoid valve :mad: . Can anybody explain what is the purpose of this solenoid please and at which instant it is suppose to operate please.
Thank you
Two Pairs of 10ft Fork Extensions (A55787)
Two Pairs of 10ft...
UNUSED FUTURE FT-XGJ 40" MINI HYD TILLER (A54757)
UNUSED FUTURE...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2006 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2006 FORD F750 XL...
2023 BOBCAT T770 SKID STEER (A52705)
2023 BOBCAT T770...
