TN90f "internal" clutch adjustment. anyone know how?
   / TN90f "internal" clutch adjustment. anyone know how? #1
Charles
Erie Pa
Ford 545D
I have another thread on a similar topic, but its old so...
I am replacing the clutch plates that attach to the flywheel.
I am trying to adjust the clutch release levers on my TN90F standard type shuttle transmission.(not hydrostatic or automatic).
The power train section of the repair manual tells me to fit a gauge on the centring dowel and get a clearance of .004in.. i will use a feeler gauge for the distance... OK i get this part.
The gauge in question is just a flat piece of steel with a hole in the middle and 3 "leg pins" sticking down. I have the gauge.
I do not understand how I am suppose to get the overall distance from the face of the clutch plate in order to do this. Does the centring dowel have a stop on it or some way of setting the distance before i have to set the arms within .004" of each other? if so what is that distance?
not to mention there are 6 arms, 3 arms are for the inner clutch plate, and 3 are arms are for the other plate. they are at different distances from the drive plate face. SO, only 3 arms at a time will be within .004 of each other, not all six. I hope i am making sense here.
is there a place that I can get the proper distance measurements
thanks
Charlie
Well, as crazy as it sounds, its cheaper to buy a "clutch group" re-manufactured ($580) rather then get the tools ($500) and the plate ($400) and resurfacing ($?). Even a brand spankin new clutch group is still worth it at ($1050)
I like how they make it so doing your own work is more difficult (they wont give u the measurement for the clutch adjustment) and expensive then paying them to do the assembly work.
They honestly want $320+ for a steel rod cut to length with some SIMPLE lathe work done to it. Then they hide the dimensions so you cant make one...nice NH
Oh well, I am done cryin now.. lol
I hope I can put it back together b4 I am snowed in.
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
Miscellaneous electrical stands (A53117)
Miscellaneous...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2009 Ford F-550 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2009 Ford F-550...
