tn85a lost fwd
   / tn85a lost fwd #1
sammyd
Bronze Member
was out moving snow and all of a sudden the tractor couldn't pull itself off the road. Looks like the front wheels are not trying to move. Switch is on and the light is on in the dash. Operators manual is less than worthless. I found a picture of a fuse and relay panel but it doesn't tell you where it is and nothing about the fwd in the troubleshooting section. I have part of the lower dash removed from another issue and I don't see it there. This has the 16x16 with electric shuttle. Any hints or clues....Where are my fuses and relays? Is there a solenoid somewhere that needs some attention?
thanks
   / tn85a lost fwd #2
Start to check the mechanical bit, it's common to use oil pressure to disengage 4WD on tractors so a dead solenoid should get you permanent 4WD. But of course not all uses this way of doing it but a basic mechanical check is quick to do.
   / tn85a lost fwd
Evidently there is a coupling held in place with some snap rings and the snap rings let go. Dealer said it is not too uncommon.
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2006 International 9400i (A52748)
2006 International...
2017 Bobcat E26 Mini Excavator (RIDE AND DRIVE) (A50774)
2017 Bobcat E26...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52141)
2018 HINO 268 NON...
2014 Ford Escape SUV (A50324)
2014 Ford Escape...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
