TN75DA Power and take off issues (not pto)
   / TN75DA Power and take off issues (not pto) #1
Bartoma
TN75DA
I have recently purchased my first New Holland TN75DA tractor. it is a 4wd. It seems like a great tractor so far, I love the size and operation. I seem to keep having a few problems and I was hoping there might be some experts on here to help. Most of the time when I start the tractor I have trouble getting the tractor to move. I have tried a different computer and shuttle shift lever. Neither has done the trick, there are no codes that it flasher, but then I move around the wired under the dash the yellow sprocket with the line through it will flash and then I can start driving the tractor, it will usually operate well until I hit a a big bump and then I must start moving wires to get going again. I've also had luck pumpkin the clutch, which I believe ultimately moves the wires and plugging and unplugging the largest relay in the fuse panel. I also noticed that the top right fuse a 50 AMP large red fuse gets very hot during operation.
This last weekend I was baling hay with it, pulling a Vermeer 504M and it didn't seem to have the power it should. I'm going to replace all the filters and see if that does the trick, but I have a strange feeling it has something to do with the turbo charger?
Any suggestions or methods of testing or narrowing the hunt?
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Case 480E (A50120)
Case 480E (A50120)
2008 Volkswagen Passat Passenger Car (A51694)
2008 Volkswagen...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
