TN75DA Need owners manual info for in cab controls
   / TN75DA Need owners manual info for in cab controls #1
skidsteer.ca
Western Ontario
Bobcat 553, 773, S185, Nh LS 160
Hello
We just purchased a 300 hour 2005 tn75da with cab and fel, however the owners manual is m.i.a.
Could anyone with a simular tractor send me a copy of a few pages from their manual showing what the various controls in the cab are. we have figured the obvious one out, but could use a little help.
Ken
kenkreger@yahoo.com
   / TN75DA Need owners manual info for in cab controls #2
Can you post a pic of the controls you are wondering about and I will do my best to answer them. I don't have a new cab tractor manual on hand to be able to scan or fax from other wise I would.
Also, Ebay is a good source for manuals. They usually have a few New Holland manuals on there.
   / TN75DA Need owners manual info for in cab controls #3
yeah, describe the control and we could tell you what it does.
or just ask call up NH customer service and ask for one, i'm sure they would send one out.
Ok the next time I get out to the farm I'll take a pic or two. There are somelevers beside the seat and a switch on the rh inner fender from the top of my head and ....
Ken
   / TN75DA Need owners manual info for in cab controls #5
Ken
Are the levers to the right of the seat? If so they are either the lift and draft control or if they have colored handles on them they are most likely hydraulic controls for the rear remotes. The switch on the fender should be the automatic lift control for the 3pt. Once you set the 3pt height you can use the switch to lift the implement on the 3pt at the headlands, when you turn and are ready to go back to work you hit the switch back and it lowers to your preset height.
   / TN75DA Need owners manual info for in cab controls #6
I've had 2 TN cab tractors and I can tell you that they did not have the same controls in them at the same locations. I have an extra manual for a TN75S (supersteer) if that would help.
PM me if you are interested.
Andy
   / TN75DA Need owners manual info for in cab controls #7
Andy
The controls are not all in the same exact postition but most of the rear 3pt and hydraulic controls are similar in position.
I have spent a bit of time in cabbed TN's and there is very little difference from my perspective to go from the open station to the cab model. Most of the levers are right where I expect them (this was on the original TN 65 open station and TN 75 cab)
   / TN75DA Need owners manual info for in cab controls #8
Robert
this is true for the normal 3 pt and rear remote controls. What really varies is PTO, diff lock, lights, wipers and the electro hydraulic that complements the standard 3 point studd.
Andy
NEW Woods 6ft Finish Mower (A53473)
NEW Woods 6ft...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
1993 Ford F700 Stakebody Flatbed Truck (A51691)
1993 Ford F700...
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A53426)
2002 MANAC 48'...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
1992 GROVE AP-308 CRANE CRANE (A53426)
1992 GROVE AP-308...
