TN75DA issues again
   / TN75DA issues again #1
Cowfarm
New holland
Seems like this tractor has been plagued from the start... something always wrong. Well anyway if you shut off engine for 3 or 4 hours it starts easy. Leave it set 2 days and it will crank and crank but no start. A shot of starting fluid and it starts right off. An I getting bleed off, anyone have this problem before?
   / TN75DA issues again #2
"An I getting bleed off"?? what are u saying here??
Have u tried anything?? Have u loosened the inj. pump INLET bolt to SEE if your getting "drain/bleed back".??
Fuel draining back to the tank & your initially pumping air to the inj. pump inlet instead of fuel..
IF u KEEP spraying starting fluid in it, your going to be doing an engine overhaul instead of replacing a supply pump.!!
   / TN75DA issues again #3
A plugged fuel filter or possibly a lift pump going bad??
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2016 COTTRELL EZ5307XL CAR HAULER TRAILER (A52141)
2016 COTTRELL...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
