TN75D-Change boot shifter--remove gear shift knob
   / TN75D-Change boot shifter--remove gear shift knob #1
Charles Mc
New Holland TN75D
Can anyone give me some information on how to replace the shifter boot on my New Holland TN75D tractor? I cannot get the shifter knob off...I have seen where it says to heat the boot and slip it on (turned inside out). The new boot hole seems to be so small to go over the shifter knob. Any suggestions are appreciated!
   / TN75D-Change boot shifter--remove gear shift knob #2
Welcome to TBN. I have taken the shifter knob off to do this. The knob is a tolerance fit over the shifter, but it can be difficult to get off and sometimes remains somewhat loose after replacing.
   / TN75D-Change boot shifter--remove gear shift knob #3
I agree with this. I no longer have my TN75D but I did remove the boot. Just kept turnign adn wigling until it came off. A little glue helped upon replacement
Andy
Thank you all for your responses. I figured if I kept on wiggling the knob would eventually come off but then wouldnt want to stay on even with epoxy as I know a lot of vehicles dont stay. So, I did heat up the boot and stretched and stretched until it fit across the knob. Sure did think it was going to rip the boot but it didn't.
   / TN75D-Change boot shifter--remove gear shift knob #6
Glad that worked for you.
On a side note, I worked on a few TN tractors without cabs and found a HUGE price difference between the shift knobs for cab vs non-cab on NH tractors with the latter being reasonable.
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52128)
2017 Yale GLC050VX...
Land Honor Quick Attach Big Arm Backhoe (A50515)
Land Honor Quick...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
