tn75a block heater installation
   / tn75a block heater installation #1
loader67
How do I get the plug out to install this? Looks like it is about a 26mm hex is needed to get the plug out. Is there a special tool I need to buy?
   / tn75a block heater installation #2
After draining the cooling system, knock out the core plug by usng a punch and hit it near an edge. Remove the core plug, clean the bore and then follow the instructions on the core plug. They are usually installed dry ( no Permatex or other sealer).
   / tn75a block heater installation #3
I took a 3/4" x4" bolt and ground three sides of the hex down until the bolt head fit the female hex of the threaded plug. Then threaded a 3/4" nut onto the bolt and welded it solid. An 1-1/8" impact socket and a 1/2" air impact makes short work of the plug. They are torqued extremely tight at the factory. They will come loose with a socket and breaker bar. Then assemble the heater as per the included instructions. Several guys in the shop have built the same 'tool' and they have served us well. I'm not sure I want to know how much a 26MM impact allen socket would cost.
   / tn75a block heater installation #4
The plug in question has a straight thread. It is not a soft plug.
   / tn75a block heater installation #5
Opp's! I guess i missed the "hex" part of the of the original question. Thanks for the info.
The ground off 3/4 bolt worked great. Thanks!
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53473)
2018 Link-Belt LBX...
2021 Chevrolet 4500 20FT Box Truck (A51692)
2021 Chevrolet...
2006 FORD F250 SERVICE TRUCK (A53426)
2006 FORD F250...
2002 International 9200i Truck (A53473)
2002 International...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2015 FREIGHTLINER...
