Oil & Fuel TN75 -- fuel system question
   / TN75 -- fuel system question #1
jimg
Veteran Member
This past Sat I changed out my fuel filter and now my tractor isnt starting. Here's what lead up to that....
Changed out the filter as per the instructions in the OM...take filter off, spin new one on and fill filter via hand pump until fuel issues from the bleeder valve.
Start tractor...all good, idles for several minutes normally
Turned off tractor to check oil level (also changed oi at the same time)
Tried to restart tractor to move it back to the shed...the engine turns over but isnt starting
Manual says I ned to bleed the injectors which I do...however, no fuel is getting to the injectors if I follow the instructions (using hand pump). Working back from the injectors none of the lines have any appreciable amt of fuel in them even though the fuel filter is full. I cracked the filter output lines and some fuel comes out but it seems not nearly enough. Just wanted to add that its not been very cold here and even so I condition my fuel...so plugged lines I dont think is an issue. It appears that for whatever reason fuel isnt making it from the filter to the pump. Also it seems that using the hand pump (as per the instructions) I should see something eventually at the injector...but that never occurs. Any ideas??
One final observation...that back injector is very difficult to work on. :mad:
   / TN75 -- fuel system question #2
I am not familiar with your tractor, but whenever I bleed a fuel system I start at the filter and work toward the injectors. From your description it seems you have air trapped somewhere. I also fill the filter before installing if possible.
Bill
Right, this is what I thought...some sort of air lock. However, the manual doesnt lead to that conclusion. It leads you to believe that all will be corrected if you simply loosen the injector lines and use the hand pump to refill the down stream (from the filter) lines. So, why isnt fuel moving from the filter to the down stream lines when the pump is actuated???? I dont know...
   / TN75 -- fuel system question #4
I have a TL100A , it is the biggest pain in the....to get started again after running out . Ive bled everything , the only way it will start is to give it a sniff of Aerostart . As soon as it fires once , it's away . Ive bled every sort of machine you can think of , but logic plays no part in these things for some reason .
   / TN75 -- fuel system question #5
Usually on my TN, I bleed at the pump and after that it works fine.
Never had to bleed at the injectors.
It's real easy to strip the bleeder on the filter, if you do that, you'll get air in it all the time.
Yes, that was my experience previous to this. I never had to mess w/ the injectors (thankfully b/c its a huge pain to reach the back one).
Could you elaborate on the stripped bleeder stmt? How did you know it was stripped? Mine *seems* ok in that I didnt over tighten and it doesnt just spin in its hole. Nor does an fuel/air bypass in its tighten position.
   / TN75 -- fuel system question #7
You can not push fuel thru most injector pumps.
Right and thats not what is being discussed. According to the documented procedure the lines to the injectors should be disconnected and then the pump is actuated. LOL...then again the documented procedure says if lines fail to purge call your dealer. OK, I sort of failed on that point but thought I might get input here before going to the dealer....just in case the manual was wrong/misleading.
   / TN75 -- fuel system question #9
I was just going by what you said;
Obviously, I misinterpreted.
   / TN75 -- fuel system question #10
I read it that way too.. and i agree with you.. the I doubt the hand plunger will make fuel move to the injector, past the pump.. ( though I don't own that machine to say for certain).
All I've ever had to do on any diesel I've maintained is to fill the filter.. install.. open fuel, bleed past filter.. bleed at pump, and then bleed at injectors.. then wala... it starts. A few stubborn ones wanted a pull start the first time.. but usually starter gets it done. My 7610s spoils me with it's electric fuel pump!
soundguy
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2009 Freightliner M2 106 Ambulance (A51692)
2009 Freightliner...
New Holland C345 (A50123)
New Holland C345...
2015 GMC Acadia SUV (A51694)
2015 GMC Acadia...
