TN75 digital dash - how to change to mph?
   / TN75 digital dash - how to change to mph? #1
pokinhope
Hi,
I have a TN75DA with the digital dash. I can't figure out how to change from kilometers per hour to miles per hour. I have done it before on my previous tractor, but don't have the large operator's manual with this one, and so don't have the instructions. It was a simple procedure that used the two display control buttons. Unfortunately, I can' remember the sequence on how to push them to make the change. Can anybody help?
Thanks! /forums/images/graemlins/confused.gif
   / TN75 digital dash - how to change to mph? #2
Can not help you, but I would make a phone call to your local CNH dealer. I am sure they would be able to tell you over the phone.
   / TN75 digital dash - how to change to mph? #3
Why not try to keep either one of the buttons pushed down for maybe 5 seconds or both buttons depressed for the same length of time. May change mode.
Vic
   / TN75 digital dash - how to change to mph? #4
</font><font color="blue" class="small">( Can not help you, but I would make a phone call to your local CNH dealer. I am sure they would be able to tell you over the phone. )</font>
Learn the metric system! /forums/images/graemlins/smile.gif It is all the rage. Impress everyone withg how fast you can do something, like 10 an hour (10 KMH=6 mph). You get the idea.
Bob
   / TN75 digital dash - how to change to mph? #5
I've got a TN65D with the digital dash. Here's how I changed the speed settings over to mph:
Turn on your ignition key while simultaneously holding down the "CAL" button on your dash.
After a moment, you will see the "kph" indicator start to flash.
Release the "CAL" button.
With the "kph" indicator flashing, depress the "CAL" button one more time and you will see the "kph" indicator change over to "mph". Now, your tractor ground speed will be reading miles per hour.
Good Luck!
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
BLACK DIAMOND AIR COMPRESSOR (A53843)
BLACK DIAMOND AIR...
LAPTOPS AND ASSORTED POWER CORDS (A53843)
LAPTOPS AND...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
