Tn75 3 point left vertical lift arm frozen up
   / Tn75 3 point left vertical lift arm frozen up #1
Alvito
75tn new holland
Left lift arm top threaded part ok,....bottom treaded part.....frozen will not turn or take grease. Right side like new. Don't know if I named correctly, top attaches to moving lift arm, lower to bottom arm, any way to do with out heating. Have tried with 40 inch pipe wrench for leverage but will no budge
   / Tn75 3 point left vertical lift arm frozen up #2
I have a used hydraulic cylinder for tilt usually fixes the situation
   / Tn75 3 point left vertical lift arm frozen up #3
The proper term, if it's helpful, is adjustable side link.
   / Tn75 3 point left vertical lift arm frozen up #4
Send your wife out shopping to buy new cookie sheets. Degrease it as best you can. Use the old cookie sheets under it and set the oven to 300 degrees or so (below burning the paint temperature; or clean it off first). Let it bake. Open some windows and turn on the stove hood. Accept the ass chewing. Her stove is fine and her food tastes great.
If it doesn't work, try hotter, and then the hydraulic side link (which you really wanted anyhow).
NEW HOLLAND RG140 MOTORGRADER (A48992)
NEW HOLLAND RG140...
2022 Club Car...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
LOT LOCATIONS (A50046)
PUMP JACK (A48992)
PUMP JACK (A48992)
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A45679)
2019 KENWORTH T680...
