TN70A Code 16 need help
   / TN70A Code 16 need help #1
thejrancher
I have a 2005 TN70A 4wd, power shuttle with 16 speed transmission. Tractor starts,amber light stays on wont go out, tractor wont move, code 16 is flashing. If I turn the tractor off and restart amber light goes out and tractor moves and operates fine, code 16 still flashes. I have replaced the transmission pressure switch (upper switch inside left rear wheel) and I have replaced both range lever switches. Any ideas?
   / TN70A Code 16 need help #2
I beleive the clutch needs to recalabrated with a scanner...its just off a little you can pick up a scanner for a about $300.00 I beleive.good luck someone will be by later with some more help
   / TN70A Code 16 need help #3
I'm no tusre if this is help, but I have had issues with my TN55 (shuttle clutch) intermittently doing something similar. It has been doing it for a long time now, and I have worked out a method to combat it.
On start up, ~30-40% of the time I get a warning light (flashing amber gear light as I recall) when I put the direction of travel lever in gear (sorry, it may be after I start it and before I move the lever; really all it does is control the direction of travel that the clutch locks up in). This eventually transitions to a flashing red light (the 'read your manual and do what it says' light). If I waited for ~90 seconds or so, then re-engaged everything it would still work, but with the flashing manual lamp lit.
I finally figured out a few months ago that if I give it some fuel and get the alternator lamp off (and a bit more) that I don't have this problem anymore. I think mine was simply a low flow error due to cold start up, though the codes indicated another issue (trans or range gear selector issues -- even though the switches and wiring all looked good and ohmed out).
Good luck on yours!
2012 FREIGHTLINER CORONADO (INOPERABLE) (A53843)
2012 FREIGHTLINER...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
