TN70- name the part
   / TN70- name the part #1
koamfps
Michigan
NH TN70DA & NH 2120
Ok, so I'm stuck on stupid. You know the part on /in the rear axel that hooks to the lift arms for the 3 point so they go up and down.... What is that part called?
Are the seals relatively easy to replace? My left side is leaking
Sorry for my ignorance
..Ok so maybe I'm not getting it.. I went to NH site it says it's a implement carrier and from what I can match up it has a bar that slides through the back of the Transmission that the implement carrier arms attach to on each side and appears a seal is leaking.... Is this making any sense or am I spinning my wheels still? Confused
   / TN70- name the part #4
i believe the bar you are talking about is called a load bar atleast in a jd tractor
   / TN70- name the part #5
Are you talking about the pivot pin for the three point lift arms? It's situated at the bottom of the rear axle housing and the lift arm pivots on it when you raise and lower the three point hitch.
   / TN70- name the part #6
If the leak is at the tractor end of the lift arm, you are on the right track. order a seal, o-ring, snap ring, spherical bushing, and take a very good look at the torsion bar where the bushings & seals ride. If you have one side leaking, might consider doing both. Place position and draft levers fully forward/down before removing the bar.
Thanks Rick. 2 questions If only on side is leaking why do the other side Lastly I get the seal and the O ring why the other parts?
   / TN70- name the part #8
Beacuse if one side is leaking, the other is likely to leak soon, and/ or will be damaged in the course of the repair. New Holland recommends bushing replacement and it is often damaged in removal. The nature of the snap ring and its placement is such that it is cheaper to sacrifice it than spend $1.20 per minute (shop labor rate) to remove it intact for re-use. Your mileage may vary, and the economics of a DIY repair coupled with your tolerance for the odds of re-visiting the leak due to an incomplete repair may be different than that of a professional repair shop. I will tell you upfront that the spherical bushing is not cheap.
   / TN70- name the part #9
I changed both of them on my tn 65, took about 45 minutes. Easy Peezy. Just get the parts from NH, and a few tools, done.
Darwood when you changed them did you only change the seal or everything?
Also I assumed u had to brain the fluid as well
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
JOHN DEERE  EURO BUCKET (A52472)
JOHN DEERE EURO...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
