tn70 hydraulics
   / tn70 hydraulics #1
jrc121
scurry tx
new holland tn 70
My tn70 3point lift and the loader will not lift. It's like the hydraulic pump is disengaged or something. Any help would be greatly appreciated.
   / tn70 hydraulics #2
The pump shaft just might be damaged.
Have you taken any pressure readings?
Have you removed a hose and placed in a bucket to see if the pump was pumping?
Are there any QD's involved.
Is the tank fluid at the proper level.
Is the right fluid installed.
More info from you might provide more answers.
   / tn70 hydraulics
Thanks J J
Fluid level seems good
Have not changed the fluid and it was working
No pressure readings
When I operate the lever for the loader nothing at all happens like there is no pressure at all, that's why I was wondering if there was a way to disengage the hydraulics that I don't know about.
   / tn70 hydraulics #4
Remove one of the cyl hose and see if the pump is pumping.
The pump shaft may be damaged and just spinning doing no work.
   / tn70 hydraulics
ok thanks I'l try that.
   / tn70 hydraulics #6
You may have lost prime.
   / tn70 hydraulics #7
As I recall, New Holland had a notice on the TN70 or TN70A (Unsure of tractor year(s) that it covered. The pump shaft that connect to the shaft in the front right corner of th engine was too tight and would twist off when it binds too much. The notice called for a smaller shim or something. But after it occurs, I believe they had to replace the pump due to the shaft being twisted off. Let's hope its not that.
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
Galvanized Livestock Gates - 4FT x 18FT (2x Gates) (A55218)
Galvanized...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
New Holland TS6.130 4WD Utility Tractor with Slope Mower (A53421)
New Holland...
