TN70 - 2nd Rear remote
   / TN70 - 2nd Rear remote #1
koamfps
Michigan
NH TN70DA & NH 2120
Has anyone added a second rear remote to their tractor? How difficult is this to do?
   / TN70 - 2nd Rear remote #2
Adding a valve slice is easy. Adding the linkage on a cab tractor can be difficult, open station tractors are easy. Kits have decent instructions. Paying for the kit hurts.
Rick,A cab is harder because you have to remove the inside panel ?
   / TN70 - 2nd Rear remote #4
A cab is harder because the lever pivot supports more then one lever and is bolted to the underside of the cab and covered inside by trim panels. The levers on non-cab models are much more spartan and usually can be assembled on the fender while sitting in the seat.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
2015 DODGE RAM...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
