TN70 2002 transmission grind
   / TN70 2002 transmission grind #1
fieldman12
OHIO
2001 New Holland TN70,2003 John Deere 250 Series II skidsteer,1987 John Deere 2155,2013 John Deere 5055E MFWD,2007 Duramax 4x4 truck, 1973 MF 165,Artic Cat 550 Cougar sled
I have a TN70 that has the 8x8 non syncro transmission with the manual forward/reverse shifter on the left. The tractor has very,very low hours. I notice that when I push the clutch in and want to move the left shifter to forward or reverse at times it grinds especially if the rpms are up. Now once I get in in gear I can push clutch in and go from forward to reverse fine or back and forth fine. It seems to only grind when I put the left shifter in neutral and let clutch out. Can this be adjusted or is this somewhat normal for the non syncro transmission? I always thought the forward and reverse lever was syncronized but I am not sure.
   / TN70 2002 transmission grind #2
Is this worse at low temps, or better at high? How many hours, in 11 years? Did the clutch ever get stuck?
I'm thinking drag in clutch parts ( pilot bushing, junk on disc or pp, release brg hanging up on sleeve) or sluggish rotation of gears in reverser or trans.
Jim
377694 (A51572)
377694 (A51572)
2013 RAM 4500 (A50323)
Unused 2025 CFG MX20R Mini Excavator (A50322)
Unused 2025 CFG...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
