TN65S Power shuttle fault
   / TN65S Power shuttle fault #1
freedomfarmoh
Chardon, Ohio
TN65S TN55S
This TN65S is acting up again . . . last fall I installed a new power shuttle lever unit and it worked well until now. There are no codes flashing, BUT this is what happens:
Start the tractor, hit the 4WD switch to put it in two whell drive, select a gear, move the shuttle to fwd, release the clutch, and nothing. No fault lights at this point either. With this TN65S and a previous one, when you first start the tractor and it's at an idle, the battery light comes on until you tap the throttle a bit (to excite the alternator?) and then it goes out. At the very instant you bump the throttle and the alternator light goes out, THEN the power shuttle fault light comes on and you still aren't going anywhere. (the light is yellow/orange gear with a line through it).
Any suggestions/help/info is greatly appreciated. I'm going back to it now for further wire checking and ground checking again . . .
Steve H
Problem resolved . . . :thumbsup:
After scratching my head and over thinking this, I removed the rear left wheel to access several wire connectors to sensors & switches. I simply unplugged them, inspected them and plugged them back in. Started it up and all is good . . . I am a bit suprised that NH doesn't use sealed connectors.
Steve H
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
PRO WORKS PWFF LOT IDENTIFIER 15 (A53084)
PRO WORKS PWFF LOT...
UNUSED LANDHERO CHAINS & BINDERS (A51248)
UNUSED LANDHERO...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2019 TAKEUCHI TB290 EXCAVATOR (A51246)
2019 TAKEUCHI...
