TN65S - Fault Code appearing after service
   / TN65S - Fault Code appearing after service #1
JohnM575
New Holland TN65S
Hi there,
Our TN65S has fault code "51" appearing on the dash which has appeared immediately after getting the tractor back from service.
After calling the mechanic, he mentioned that the computer may not have cleared the memory of the error after fixing all the problems.
If someone could please inform of what code 51 is that would be much appreciated, as the tractor is being used for full days of work at the moment, with the "fault" being inapparent in the use of all the gears, pto, hydraulics etc.
Cheers.
   / TN65S - Fault Code appearing after service #2
Transmission temperature sender open circuit. Is the connector loose or off the sender?
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Cargo Mate Enclosed Gooseneck Trailer (A53117)
Cargo Mate...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
