TN65D Cab suprise!
   / TN65D Cab suprise! #1
KenPauling
Northcentral PA
Now Holland TN 65D with Cab
I was mowing yesterday in 95+ degree heat with my AC on and when I mowed across a slight hill I had water pouring in the right front side of the cab! The tractor was leaning slightly to the right and the water poured in from the ceiling. I know the AC unit or part of it is in the ceiling but its weird to get drainage into the inside of the cab from the ceiling. The water didn't come from outside but from above! Anyone else have a shower in their tractor? I would estimate a cup or two ran down along the front right corner then it stopped before I could find my soap and wash cloth! Everything works OK but something must have been blocked or misdirected.
   / TN65D Cab suprise! #2
when I was running a case 580 super m last summer that was almost brand new it did the same thing, but not on a hill it was just a slow leak all the time ended up with a puddle on the cab floor at the end of the day:eek:
   / TN65D Cab suprise! #3
The drain tube for the condenser is plugged (the condenser is above you, in the roof)
Find the drain tube (in the rear of the tractor) and blow compressed air up it.
water should come rolling out.
You want to fix this right away, it rots the carpet in the cab and sides.
My TN has never done it, but the TC does it all the time.
12 in Small Excavator Bucket (A52377)
12 in Small...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
