TN65 and No-till drill
   / TN65 and No-till drill #1
welder1
How will a 2WD TN65 do with a 7ft No-till? (Rolling terrain with moderate hills), Drill is a Great Plains pull type.
   / TN65 and No-till drill #3
I assume you have AG tires (R1) 28's or larger with wheel weights and loaded tires.
If that is the case, just make sure the grass is reasonably dry so it doesn't push you downhill. Otherwise, should be no problem.
I too have used a large Great Plains no-till drill and my land is quite hilly. No problem except I accidentally popped the clutch (foot slipped off the pedal) once and lifted the front tires higher than I was comfortable with. FYI, I was ballasted to about 8800 lbs. Your TN65 might be significantly lighter. Consider front suitcase weights.
Thanks for the replies, I don't own the tractor yet, just considering purchasing it and pulling the drill I can rent from my County soil conservation district is the main concern.
   / TN65 and No-till drill #5
I pull a 10 foot no till with no strain to the tractor at all with our TN65. This is a very good tractor choice. We have had no problems at all with ours.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
