tn60a starting problem
   / tn60a starting problem #1
klingen
NH TN60
My tn60a doesn't even turn over when turning the key. I am guessing that the safety starting switch is sstuck or bad (with the manual shuttle in neutral). Anybody know where the switch is located? There isn't a diagram in the manual, i have crawled around underneath and I can't find it. Otherwise, any ideas on other possibilities?
Gotta get the blade on and get some snow cleared! You know the story...
   / tn60a starting problem #2
You did check battery to see if it is charged? Lights work?
   / tn60a starting problem #3
Mechanical shuttle NSS is a ball switch in the side of the transmission housing just below and in front of the park brake handle. If the PTO icon remains lit with the tractor off and key on, the PTO NSS circuit is the culprit.
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
199049 (A51243)
199049 (A51243)
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
