Hello fellow NH owners,
I own a NH TN60A FWD with the 16x16 EHSS transmission. The tractor has the 32LC loader and the 759C backhoe. I use the tractor around my property for light work - Mostly brush cutting with the Landpride 72" brush cutter.
The tractor was purchased new in the summer of 2005.
At 150 hours of operation at the start of last season (early 2008), the tractor would no longer move... engine running, range and gear selectors firmly in place, clutch pedal out, operator on seat, forward/reverse lever either direction... No movement from tractor. Normally, I would hear a small 'click' noise after moving the direction lever in either direction... an indication that the transmission was engaged, then the tractor would move. Now, No 'click', no movement.
I had no choice, but to transport the tractor to my local NH dealer/service shop where the tractor was diagnosed with a faulty (bad) trasmission control module (part # 87575340). The part was replaced and all was well.
Now, working with the tractor this season at 200 hours of operation, the tractor, although not disabled, is showing some signs of the same trasmission problem. After working for roughly an hour or so, the tractor will decide not to move, forward or reverse. An attempt to put power to the wheels occurs (a soft movement), then, no movement. Fwd/Rev level still in position (didn't jump to center).
I am concerned that I'll soon be back in the same predicament.
One thing I am noticing is that prior to the first incident, the transmission status lamp would flash a trouble code. I don't remember what it was. I can't say I've ever seen the same status indicator flash out a trouble code since the tractor was in the shop the last time.
Any suggestions as what to do with this? My first work *was not* covered under warrant even with the small number of hours on the tractor.
Am I looking at another transmission control module replacement? Is this something that I could replace or is there more to this than just replacing the appropriate part.
I certainly would appreciate some insight to my problem from this community.
Thanks, Scott
Souther Tier of New York
New Holland TN60A with the 16x16 EHSS Transmission
Thanks, Scott
