Kregan87
Hey, new here. I've searched around a bit and haven't found the exact situation I have. Had an intermittent problem for a year or so of my 2000 NH TN55 not shutting off with ignition. So I replaced the ignition switch the first time and just by coincidence it worked for about 6 months. Then started acting up again. I ordered a new fuel shutoff solenoid which on this tractor gets power from ignition and open up flow of fuel. When ignition is shutoff the solenoid looses power and the plungers falls closing the path for the fuel. Well I replaced the solenoid and no change. I can remove 12v power from solenoid all together and it doesn't shut tractor off. Could it be the passage the plunger falls into in the injector pump is dirty or clogged preventing it from falling into place? Any ideas I would really appreciate it!
