TN55: 8x8 v 12x12 or 16x16
   / TN55: 8x8 v 12x12 or 16x16 #1
mojoinco
Platinum Member
Colorado
TN55
Hello all, I am working delivery of my new (for us) TN55S. Yeah! Old Yellar (Case VAC14) will be getting the boot soon. Always worked, and I could always fix what ailed it. Will find out on the new Blue I-talian (Alfa-Lanc-errar-iat).
Anyhow, it is an 8x8 power shuttle. I was looking over the parts diagrams (on line) and am wondering what the difference between the different transmissions. Primarily if the trans is simply a one for one swap (if you had a 12 or 16 speed unit). And what is the creeper option -- it looked like another range to me.
Enjoy!
   / TN55: 8x8 v 12x12 or 16x16 #2
8x8 isn't enough gears
12x12 or 16x16 is way better.
in an 8x8, you'll always be searching for a better gear and you won't have it
not a problem in a 16x16.
Much easier to put the tractor in the proper RPM range with the right speed.
   / TN55: 8x8 v 12x12 or 16x16 #3
My 2120. same frame tractor as the TC55 is a 12x12 and that is a good set of ranges for most uses. A creeper isn't really more ranges, it adds a very very low speed range. It is mostly useluf for things like precise seeding and spraying where application rate is controlled by ground speed not ordinary tractor operations.
Andy
   / TN55: 8x8 v 12x12 or 16x16 #4
Brian, I don't think New Holland even offers the 8x8 in the TN anymore. I have it in my TN65 and while it will do the job I will never buy a new tractor with less then 12 forward gears. For a basic ranch tractor it does the job though. My use expanded drastically since I bought my TN back in 99.
On the creeper: the diagram and other things I have seen looked as if it was a super-low range - not another gear.
Anyone ever taken a look at how different the 8x8 is versus the 12 or 16 pseed trans? Would there be any possibility of a case swap, or of a gear set swap? Just wondering.
   / TN55: 8x8 v 12x12 or 16x16 #6
Anything is possible, but the costs would be so prohibitive that finding the correct tractor would be much easier and cheaper.
Andy
I figured it would have to be one of those -- oh, lookey there lieing in the yard -- sort of thing. Found strange things before (and spent a lot of hours on the web to figure out what-fits-what). That's one of the beauties of these groups -- ask long enough, hard enough, in enough different ways and sometime what you are looking for comes your way. Sometimes.
2008 Volvo XC90 SUV (A51694)
2008 Volvo XC90...
2009 Wells Cargo 5th Wheel Office Trailer (A53117)
2009 Wells Cargo...
Ford 4630 (A50123)
Ford 4630 (A50123)
2017 HINO BOX TRUCK (A53426)
2017 HINO BOX...
2023 Yamaha Wave Runner Deluxe (A51694)
2023 Yamaha Wave...
