TN 75D steeing squeaking
   / TN 75D steeing squeaking #1
MikeF
Maryland
JD 3039R cab
I think I saw something on this issue a while back, but cant find the post. My steering makes a squeaking noise that goes away if you adjust the teliscopic position, but comes right back. The noise is driving me crazy! Anyone know what to do?
Thanks Mike
   / TN 75D steeing squeaking #2
I've noticed the same thing on mine.
   / TN 75D steeing squeaking #3
Something similar to a rubber band is used to hold the column trim panels together under the upper steering wheel shaft cover. Extend the wheel fully upwards. Take the screws out of the upper half of the lower column cover and remove it and cut the band off. Replace the lower column cover and no more squeak.
Thanks for the cure! It will make this years hay making so much more peacefull.
Mike
   / TN 75D steeing squeaking #5
When I had my TN in for warranty work the squeak was one complaint. They replaced my entire steering column, at least that's what they said. But the annoying squeak is gone!!
I like RickB solution much better.
I also had a squeaking noise from the clutch pedal pivot. The took it appart and greased it. Squeak gone.
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
2019 Infiniti QX60 SUV (A50324)
2019 Infiniti QX60...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
