Tn 75
/ Tn 75 #1
Simpkins85
Bronze Member
I have a Tn 75 4 wd drive 2003 model 750 hours on it and when ever it run for a couple hours like when mowing hay or baling. Sometimes when you push the clutch in and go to let out on it the clutch feels like it is slipping and make a pretty bad noise. Any suggestion on what it might be it only does it when it gets hot?
/ Tn 75 #2
Well, just a simple guess here, but it sounds like a bad throwout bearing or a pilot bearing to me. Either will not be fun.
Might want to read up on how the clutch functions on the TN models. Does it matter if you are engaging in the forward direction or the reverse direction?
Any codes flashing?
/ Tn 75
Somebody told me that my rear main seal might be leaking into my clutch when it get hot and drying it out
/ Tn 75
I meant to say that I think the rear main is leaking into the clutch and getting wet
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
Harper TV130 High Dump Turf Vacuum Sweeper (A59228)
Harper TV130 High...
2006 International Bucket Truck (A60352)
2006 International...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
