TM2370CD for Serial #770631
   / TM2370CD for Serial #770631 #1
jcalla
Triangle, VA
Where do I find TM2370CD for my 4720 serial #770631? The highest number available is up to 650000.
JPC
   / TM2370CD for Serial #770631 #2
About what year? Is it a cabbed unit?
2010 w cab
   / TM2370CD for Serial #770631 #4
Ok. I have a manual for that era of open station machine...not one for cab
   / TM2370CD for Serial #770631 #5
Arlen4720,
Could you possibly post the pages of the TM2370 that show glow plug theory of operation, wiring diagram and troubleshooting?
Thanks,
JPC
   / TM2370CD for Serial #770631 #7
This should help. It is pages from 3 different sections. Good Luck. Not a good time for glow plug problems.
  • Glow Plug Pages .pdf
This is good. I assume this covers my 2010 4720 even though I have a cab. My tm2137CD that was sold to me when I bought the tractor, covers earlier version of 4720 not mine. Would it be possible to email me the complete CD so I can search through it and see the color code if the circuits? I would gladly pay you for it.
JPC
I see where aid goes directly to K5 which is working fine, however I am trying to find which wire goes to the display with the switch in run and is supposed to light up the indicator light. It looks like it would be wire 4 or 5 from the switch that powers the display in run. PDF file came in black & white so I can't tell which circuit it is. Could you tell me what circuits 472A and 072A are? Do you have the other part of the schematic that shows where power goes in and out of the display?
JPC
   / TM2370CD for Serial #770631 #10
JPC
Wire 383 coming of the load side of the contacts is the one that goes back to the ICC to tell it when glow plugs are active. Wire 385B that is landed on the coil of the relay is coming from the engine computer. That is the one that fires the glow plug relay automatically when it is cold. 385A is coming from the manual switch to fire glows manually.
If glow plugs are working (manual and auto) and it is just the lite not illuminating, then investigate wire 383. Where it lands on the ICC is detailed in the pdf that I attached.
Good luck
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
