TL90A moves 5 ft then stops.
   / TL90A moves 5 ft then stops. #1
Rocky67
Marysville
New Holand TL90A
I have a TL90A when I put it in gear and push the shuttle forward it moves about 5 ft then stops. At this point it won't move again until I shift it out of range and back in then it moves 5 ft and stops. The problem first started only in range 1. At the time I also had problems with the tractor dash going out and the tractor would stall from time to time. Sometimes it would restart right away and other times it took several tries before it would resart. This problem was fixed by a new ignition switch and the range 1 issues went away too. Now the problem is back in all ranges. It always stops after moving 5 ft in forward and sometimes in reverse and sometimes it runs fine in reverse. Does anyone have and idea what is going on?
   / TL90A moves 5 ft then stops. #2
Is the hydraulic fluid topped up?
Yes the hydraulic fluid is topped off
   / TL90A moves 5 ft then stops. #4
Sounds like an electrical problem/nightmare. Start by checking all your limit switches and sensors, wiring, connectors, rodent nests,...
   / TL90A moves 5 ft then stops. #5
I am thinking it is a electrical problem too... also could be a broken wire. So you would need to test a whole bunch of stuff.
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR9EH765325 (A51572)
2014 International...
2021 LIDDELL C-55 RGN (A52472)
2021 LIDDELL C-55...
