TL90 battery draining......................need help?
   / TL90 battery draining......................need help? #1
kingranchf350
Al, Alabama
new holland
I have a 2004 NH TL 90 that has a problem with the battery draining over a period of 2-3 days. I have tried to find the drain but have had no luck. Has anyone experienced a similar problem or can anyone give me a idea on where to start? Thank you for any help.
   / TL90 battery draining......................need help? #2
As a temporary solution you could install a battery disconnect switch.
R.V. sellers would be one place to obtain one as many have dual battery installations and they like to isolate them.
I found some on EBay as well.
   / TL90 battery draining......................need help? #3
Disconnect a battery lead. Take a small 12v light, like an instrument light, and clip it from the batt terminal to the removed batt lead. It should light up cuz the leakage current will be going thru it. Now start removing fuses doing just one fuse at a time til the light goes out. Do the Ignition fuse last if you get that far.
larry
Ok, I will try that. Thank you PILOON and SPYDERLK for your help.
2017 FORD F-250 SUPER DUTY (A53843)
2017 FORD F-250...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
UNUSED AGT KRW23 WHEEL LOADER (A51247)
UNUSED AGT KRW23...
2013 International DuraStar 4300 2,000 Gallon Water Truck (A51692)
2013 International...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51691)
