tl3200 pto slipping
   / tl3200 pto slipping #1
leon2
im still having trouble with pto slipping on my iseki tl3200d. wonder if anyone out there has ever repaired the pto clutch, and how big a job it is? thanks leon.
   / tl3200 pto slipping #2
I had the same problem earlier this year with my White Field Boss 37. I would be using a bushhog and when I got in tall grass, the mower would stop working. I would lift it up and it would start turning again. I purchased a sevice manual and a parts manual and did the job myself. I've never have done any major work like this before but with the help of the manuals everything went smoothly. The service manual gave the directions plus had pictures so you could see exactly what was suppose to be done. On my tractor, I had to take it apart at the behind the pto valve/gear shifter. This meant supporting both halves with jacks, one which needs to have wheels so you can separate them. My problem was the clutch support, that had grooves worn into it which allowed the hydraulic fluid leak past the seals. I could not find a new one so I had a machinest bore it out and install a bushing. With new seals in place everything went back together easily. I hope this helps.:)
thanks it does help. leon
   / tl3200 pto slipping #4
You probably need new orings for hydraulic piston. & possibly clutch facings , if it has slipped a lot. I can supply you with manuals & parts.
   / tl3200 pto slipping #5
Must be that extra 11 HP wearing things out. I've got a TL2100f, great tractors, especially the way I use (abuse) mine.
2011 Western Star Trucks 4900 SA Truck, VIN # 5KJNALDR4BPBA7822 (A51572)
2011 Western Star...
PORTABLE INDUCTION HEATER (A52472)
PORTABLE INDUCTION...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2005 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCEC19V35Z257979 (A51572)
2005 Chevrolet...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
