TL 70 Cab lights, weak ground
   / TL 70 Cab lights, weak ground #1
robdogtn
NH TL70
I have TL 70 with cab, front lights work great, but my rear lights not working. Took and swapped bulbs with front to check bulb and they are fine. Then got tester out and I am only getting 9.8 volts to light. I can go and ground to the frame and it goes to 12. Is there a schematic that would show where to trace my wiring to to fix my ground problem? It is affecting both sides of my rear lights. So I think it may be a connection somewhere. I also thought 9.8 volts would have been enough to at least have dim lights, but nothing at all.
Thanks in advance!
   / TL 70 Cab lights, weak ground #2
Thanks in advance!
Check the battery ground first. otherwise you'll need a wiring diagram to see if the lighting circuit has some special groundig point. Usually, lights are grounded through the light fixture mount.
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2017 Chevrolet Express Box Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
SHOULE PWD-10 LOT NUMBER 133 (A53084)
SHOULE PWD-10 LOT...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
