Tl 100a AC
   / Tl 100a AC #1
Rancher7
Tl100a
AC works fine for about 10 to 15 minutes and cuts off, especially when weather is hot.
   / Tl 100a AC #2
Welcome to TBN
Are radiator, condenser, evaporator, cab filters VERY CLEAN? Next would be install AC gauges & check pressures.
I also suggest to install manual heater hose cut-off valve to eliminate possibility of heater coolant control valve leaking internally allowing hot coolant to flow through heater core.
   / Tl 100a AC #3
A/C could be undercharged, causing icing on the evaporator.
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
Informational Lot - Financing (A55218)
Informational Lot...
FAKE (A52472)
FAKE (A52472)
20" Sea Container (A47384)
20" Sea Container...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
