Forks Titan Hay Frame with Three 32" Bale Spears for 3x3x8 Big Square Hay Bales
   / Titan Hay Frame with Three 32" Bale Spears for 3x3x8 Big Square Hay Bales #1
KennK
NE Wisconsin
John Deere 3320
Due to the need to move 3'x3'x8' large square hay bales (750-850 lbs each) I recently purchased a Titan Hay Spear Frame with three 32" Bale Spears for use on my John Deere 3320 tractor with a 300CX front end loader.
This frame can be found at this link: Hay Spear Frame w/ Bale Spears & Stabilizers fits John Deere
I had called them to swap out the default longer CONUS 2 spears with shorter (CONUS 2) 32 inch spears to handle the 3'x3'x8' hay bales.
The combination worked flawlessly to handle the bales (we purchased 20 bales in total - four at first to test, and then 16 more later that afternoon). The hay guy even sat on the side of one bale, told me to lift it, and bounced a bit to demonstrate how well the tractor was handling them. The tractor was able to remove bales stacked two-high from a 16 foot flatbed gooseneck trailer, and I was able to stack them three high in our barn with amazing precision. Sometimes I had to wiggle the frame up and down a bit to get the spears to fully penetrate the bales before lifting, but the hay guy said they were VERY dense bales. The most difficult thing for me was getting the spear height and angle just right to back them out of the third level bales without pulling them backward. I'm sure time and experience is needed.
I preparation for this I had filled the John Deere ballast box with Portland cement. The day before I caulked the seams with 100% silicone caulk. It took 5.5 bags of the 94 lb Portland cement purchased from Menards - filling the ballast bucket just shy of the rolled over top metal. I don't think even the other half bag would have fit. I mixed each bag in a large mixing tub (also purchased from Menards) and then shoveled it into the ballast box. I ended up using about four gallons of water per bag - adding water gradually until the mix was manageable, but not at all thin - the instructions call for 5 gallons/bag.
The hay guy did the unloading of his trailer with my tractor with amazing speed (I didn't want to risk damaging his trailer). He uses a Bobcat with a four-spear attachment to load/unload at his properties. He suggested that I fill the wheels for additional weight/stability. That will be a to-do next spring before it is time for the next load of hay.
   / Titan Hay Frame with Three 32" Bale Spears for 3x3x8 Big Square Hay Bales #2
Sounds like it worked out for you. What is the advantage of large square bales? How do they price out compared to round bales? Here, horse quality round bales are $50 to $60 at the farm or $80 at a feed store
We recently retired and moved from northeast Illinois to northeast Wisconsin with two horses.
Hay is in very short supply in Wisconsin. We're told this is due to a drought last summer and crop damage from last winter. The large 3x3x8 square bales were $110/bale plus $125 for delivery to our property. We paid cash for half up front, and then went back to pay cash for the remaining hay and for delivery. The hay guy told us his remaining supply on-site had been bought out by a yak breeder near us.
We'd used small square bales in Illinois, but we were blessed with hay provider that would load them into our barn at a great prices.
Here in Wisconsin the cost for paying someone to load the hay was prohibitive, and with us aging (and my bad back) we decided that we needed to mechanize our hay loading, which meant either large square bales or round bales.
We have found it difficult to find horse quality round bales. We'd been told buying round bales for horses is risky business - that most are better suited to cows. On top of that, we've been told there can be a lot of waste, my tractor can only lift round bales using the 3PT, and that means limited one-level storage in our barn.
On top of that, our familiarity with using small square bales made the large square bales a natural choice, especially now that I can stack it three high. It's kind of funny, my wife mentioned concern that popping the last twine on the large bales will cause it to explode across the barn. I hope that's not the case. :)
   / Titan Hay Frame with Three 32" Bale Spears for 3x3x8 Big Square Hay Bales #4
I've never been to Wisconsin, so that's interesting. I always thought of it as a milk producing state and sort of assumed that there would be lots of hay available there, but it could be like Texas and most of the hay produced is for cows and not horse quality. It's been a learning experience for me to. Seems like when I find a good source for hay, they go out of business the following year. Craigslist and Facebook have been how I try to find suppliers, but I still have to go look in persona because they all lie about how good their hay is. Glad you found a good source and have a system to make it work for you. I'm still refining my method to feed them.
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2011 New Holland Boomer 90 MFWD Utility Tractor (A52748)
2011 New Holland...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
