Titan 4K bolt on forks
   / Titan 4K bolt on forks #1
Chrisb009
Mahindra 2645 Cab
So I purchased the Titan 4K bolt on forks for the 2645. Their over kill as far as capacity but I tend to over engineer everything. The box showed up totally trashed via FedEx - really feel sorry for the driver as it weighs over 100pds. Was expecting to find the worst when I opened the shipment (what was left of the taped, bagged, ripped box) but was surprised to find everything intact and totally in order. Initial impressions are good thus far. I値l only use them for odd jobs and lifting a few things here and there but not for regular everyday use or use to move stumps, trees, etc.. I have to lift the F450 bed off the truck to replace cab vents and fix a tear in the bed from the 5th wheel plate. I値l update the thread on how they perform lifting the bed...I壇 assume they shouldn稚 break a sweat lifting a truck bed.
-Chris
   / Titan 4K bolt on forks #2
You should be fine. Truck beds aren't really that heavy, unless you are talking a utility body. You should have no problem at all. Tao strong men can pick up a truck bed, 3-4 makes it much easier.
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A45678)
2020 KENWORTH T680...
Case IH 1460 4WD Combine (A49339)
Case IH 1460 4WD...
2010 Ford F-250 Ext. Cab Pickup Truck (A46684)
2010 Ford F-250...
Golf Cart (A48082)
Golf Cart (A48082)
Allis Chalmers 6080 4WD Tractor (A49251)
Allis Chalmers...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A46683)
2004 Sterling...
