TIRES
maddog2020
farmall 45
I have a 2009 JD 4720. The rear tires are shot. They are R4 s. I replaced the front tires last year wit factory size 10x16.5. The rears are 17.5x24. I would like to replace them with 19.5x24s. I know they will fit they are only about 3 inches taller. My question is will this be a problem when tractor is in 4wd. I noticed same size tires tire vary a couple inches any from manufacture to manufacture
/ TIRES
So id i decided to go with the larger rear dire what size would i need to put on front. Is there a chart a formula to figure that out?
You want the fronts to turn slightly faster than the rear tires (called lead IIRC) and going larger on the rear will reverse that and not work.
That said look at the correct front to match the 19.5 tires. On the NH TC series the ones with 19.5 rear use a larger 12.5x16.5 front tire.
Maybe JD has an another tractor with them.
Measure the OD of both front and rear tires(new) that came OEM, measure exactly,with tires off the ground; the more precise the better the outcome.
Then apply that differential ratio to prospective new tires.
Or look up the RC (rolling circumference) of the tire, which is effective circumference taking into account expected tire bulge.
My Mahindra came with 10-16.5 on front and 17.4-24 on the rear (R4s) and I was snapping front axles quite a bit with the heavy loader work I did. After going back & forth with them and busting a front diff. I had to repair out of warranty, they told me the tractor should have had 16.9-24 on the rears from the factory. I had to purchase the tires myself and sold the originals to a guy with a backhoe. The axle breaking dropped to virtually none after the tire change. In later years I also went to 12-16.5 for my fronts and has been doing well for quite a few years. Lack about 3 hrs. of hitting 3300 hrs. on the clock.
If you put larger tires on the rear then you are changing the ratio between the front and rear... something is going to break and that something will be expense parts. If and I do mean IF you really want larger tires on the back then change to fronts to larger ones as well.
But what is it you expect to gain from the larger tires?
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2019 F-550 Bucket Truck (A61307)
2019 F-550 Bucket...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
