Tires tires
   / tires #1
Anonymous Poster
Epic Contributor
I have a 1981 kubota 900 hours on it. I have bridge stone tires
They have cracks in them.
Should I get new tires.
   / tires #2
Chuck,
To me, if they still hold air and traction is not a problem, keep the tires as long as you can. New tires can cost some pretty big bucks.
MarkV
   / tires #3
You may want to replace the tires to prevent a flat tire situation that would put your tractor out of service when you need it, as they are only rubber, and most of the tire manufacturers only warranty weather cracking (dry rot) for 4-5 years
   / tires #4
Forget buying new tires.
I have a 1984 JD 316 with tires cracked so bad you can see the air inside the tires, Just kidding.
All tires were cracked and the front ones started to leak. Took them down to my local tire dealer and he put tubes in all the way around. that was 6 years ago and everything is still peachy. Tubes installed cost me $65.
I am storing my Bx inside to prevent the same tire damage.
Winnipeg, Manitoba
2001 BX2200 (15 hrs) All Kubota FEL,Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52128)
2023 New Holland...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
(3) 14' X 14' ROLL UP DOORS, W/ MISC BRACKETS (A51244)
(3) 14' X 14' ROLL...
2015 Nissan Pathfinder SV SUV (A50324)
2015 Nissan...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
