Tires Tires
   / Tires #1
mtushmoo
I'm looking for replacement front tires for a Yanmar YM1810D.
The current ones (what's left of 'em) are 5X14 tractor lugs. Since I cut grass with the tractor, I'd like something a little less aggressive.
Tire places look at me like I'm nuts when I show up.
Any ideas?
Eric K
   / Tires #2
I have had very good luck with tires purchased from Aaron @ Hoye Tractor. The lug design was less aggressive than the originals and circumference was correct for the MFWD.
Purchased four sets in less than a year (4 different tractors)
Regards Mark
******forgot about their banner at the top of the page...You may want to look around in there /forums/images/graemlins/grin.gif
   / Tires #3
Eric,
Welcome to the board! Bridgestone makes a 6-14 turf tire part number 344-362B that most Firestone tractor tire dealers. It will be slightly wider. You can visit www.firestoneag.com to be sure they will be the same diameter. If not, you will need to change your rear tires to match your tractors front diamter/ rear diameter ratio.
Hope This Helps
Aaron
Parts@HoyeTractor.com
(940)438-0386
   / Tires #4
Eric,
I just seen a set on Ebay, item number 3841814029. Looks to be what you are looking for.
Rich
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
LMC LOT NUMBER 143 (A53084)
LMC LOT NUMBER 143...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
Adams 5 ton Fertilizer Buggy / Wagon (A53472)
Adams 5 ton...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
