Tires Tires
   / Tires #1
king1010
Massey 230(1978)
I have a 230 MF 1975 w/o front end loader I can't tell what size tires to buy. I have bought 16x6. The rim is 16" Will this work on the tractor?? Light duty work around the ranch only with this tractor. /forums/images/graemlins/confused.gif :
   / Tires #2
king1010, Welcome to TBN, It appears to me that you have already bought 16x6 rims?? Are they tractor rims or implement rims? Either will work but I would suggest if you are going to use implent rims instead of tractor rims,that you shouldn't put ribbed tires on the implement rims..either use implement tires or car or truck tires. Reason is the tractor rims are made stronger for the torsional pressure the rim receives during a hard turn in a plowing situtation and the implement rims are not.
With all that said 6.00x16 tire should be fine for that tractor up to 6.50x16 should also fit fine .
I have implement rims with implement tires on my old 135 and it works great around here doesn't tear up the grass and gets plenty of steering traction..
   / Tires
The rims came w/ Tractor 1975 MF 230. 16x6 Rib 6ply tires will work /forums/images/graemlins/confused.gif?
   / Tires #4
In a word Yes /forums/images/graemlins/grin.gif /forums/images/graemlins/cool.gif
   / Tires
They work Great!!! /forums/images/graemlins/laugh.gif /forums/images/graemlins/blush.gif
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2022 CATERPILLAR 249D3 SKID STEER (A51242)
2022 CATERPILLAR...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
1996 Monon 45X96 Dry Van Trailer (A52128)
1996 Monon 45X96...
(4) 12' Steel Gates (A50515)
(4) 12' Steel...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
