Tires tires
   / tires #2
5-14 is the tire, and I expect the rim is a 14" by 4" wide (inside the bead).
Welcome to TBN.
   / tires #3
Front or rear tires/rims?? I think (but am not sure) that the rears are a 24" rim. With 4wd you will need to make sure your rolling circumference (roughly equal to circumference) ratio front to back is the same as original if you change tires or rims. Hopefully someone with the same tractor as you can just measure theirs for you. If needed I have a set of rice tires in great shape on 22' Yanmar rims from a YM1500. But I think these are likely too small for you. Data on rolling circumference can usually be found on the tire manufacturer's web sight. Good luck.
   / tires
thanks guys.....i just bought an 1802d about three weeks ago and after reading about the rolling circumference on the 4x4....kinda got me wondering and a little panicky about maybe someone had put the wrong rims on because the 22" rims seem to be a little undersized.....and my thoughts turned dark as i could see my tractor fly apart on me....so thats why i wanted to know the factory size rims and tires.
BESTWAY AG LOT NUMBER 53 (A53084)
BESTWAY AG LOT...
Electric Concrete Mixer (A51573)
Electric Concrete...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
